- Aug 10, 2020
I've had issues with bad teeth since childhood and have had most pulled by the time I was 35, my mother lost all of hers when she was 16 so it runs in the family. So I finally decided to get a couple of implants that will hold the lower denture in place. The procedure was to pull the two teeth and then replace them with the implants drilled directly into the jawbone with supplemental bone grafting at the same time, which was done on Tuesday.
I don't like to mess around with narcotics so I've been getting through on Tylenol and Ibuprofen but wow, there's a lot of pain from this procedure. I suppose it should be expected as they're opening up the gums and drilling into your jaw bone but in the long run it should be a nice permanent replacement for stability down there. Just now starting to feel like it's recovering for the first time this week.
