- Reaction score
- 11,801
The other day my AirPods weren’t connecting to my iMac. It saw them in the options but just kept showing the spinning circle trying to connect. No issues connecting them to my iPhone, iPad, or Apple TV at the time. Just my iMac. I tried several troubleshooting methods that didn’t work. Then I saw a suggestion that I turn Bluetooth off and then back on. This is where things got ugly.
You know what else connects to my iMac over Bluetooth? My keyboard and mouse. Can’t turn Bluetooth back on without a mouse. Then I read a suggestion saying to hard reboot the iMac and it would turn Bluetooth back on automatically. It didn’t. And I tried multiple times. Before you suggest I need to reboot while holding down a key combo I need to remind you that I couldn’t use the keyboard because Bluetooth was shut off. More on that later.
After that there was a suggestion to plug the mouse into the computer with a cable. Great, except the genius engineers at Apple put the cable port in the bottom of the Magic Mouse which disables using it as a mouse. To fuck with you further if the mouse is plugged in it does see if you turn the mouse switch on or off and lets you know that on the screen. WTF is the point of that?
So I asked my roommates if they had a wired mouse. Of course they didn’t. Almost nobody does. So off to Target I went to get the cheapest wired mouse I could find.
Plugged in the mouse and it worked! Sweet! Clicked on the login and got the password prompt. Which I can’t enter without a keyboard. FUCK! Back to Target to get the cheapest wired keyboard I could find.
So about 2 hours and $30 in hardware + gas money later I recovered from the “just turn Bluetooth off and back on” advice. At so many points it didn’t “just work”.
