Great use of an e-ink device
Vaccinated
Moe's
Speaking of e-ink: when I got my current car, the dealer left the e-ink "window sticker" in the back. It's a pretty neat system, it uses wireless to update prices, it's integrated with the central dealer pricing data, etc.
Anyway, I contacted them, said I had it, just to send me a shipping label. They never did, so it became mine.
Here's the kicker: I picked the car up on Aug 9th, 2019, so this device is at least 14-15 months old, and it's STILL RUNNING.
Mark
Hokkaido
@theSeb
this e-ink device set to show the actual daily updated NYT front page in near actual paper format dimensions is perfect ! seriously want one !
Software & license​
Includes access to the Visionect Software Suite, in charge of running an electronic paper sign.
  • Universal web CMS support. Easily display any web link, allowing for compatibility with all major content management systems.
  • Improved screen content performance and intelligent screen updates.
  • One-stop device management. Upload images, edit device settings, access analytics, and more.
Display​
  • 31.2-inch (16:9 diagonal) E Ink® electronic paper screen
  • High visibility and contrast
  • 180° viewing angle
  • Resolution: 2560 × 1440px
  • Active Area (H/W): 27.21 × 15.31 in. (691.2 × 388.8 mm)
  • Pixel Pitch (H/W): 0.01 × 0.01 in. (0.27 × 0.27 mm). Equivalent to 94 ppi.
  • Pixel Configuration: Square
  • 16 level grayscale
  • Refresh rate: 750 ms (4 bit full screen) / 100 ms (1 bit partial)
Connectivity​
  • 2.4 GHz Wi-Fi (IEEE 802.11 b/g/n) standard, WPA2-PSK, WPA2-EAP support
Power​
  • Patented ultra low energy architecture, only 1% of the power used by LCD.
  • High performance rechargeable battery.
  • Enclosed Micro USB charging cable
  • Cordless functionality
Casing​
  • High quality anodized aluminum casing.
  • Anti-reflective, high transmissive glass.
  • Color: Slate Gray, Graphite Black
Dimensions & weight​
  • 27.84 × 16.29 × 0.53 in. (707.20 x 413.80 x 13.50 mm)
  • Weight: 8kg
Mounting​
  • 7.87 × 7.87 in. (200 × 200 mm) VESA mount compliant.
Environmental conditions​
  • Operational and storage temperature range: 32°F to 122°F (0°C to +50°C)
In the box​
  • Visionect Place & Play 32”
  • 1 x Micro USB cable for configuration and charging
  • 1 month of free server hosting
  • Access to the Visionect Software Suite
i found out more about the original guy who developed this concept.
SuperMatt
You can use it if you want to sell the car. Or can you hack it to do something like the projects seen here?
