- Sep 26, 2021
wish they made an 8-bay tower. My synology’s are 12 bay (and really old), but when the day comes I need to replace them, i may go with one or two of the rack-style unifis.OT, but the UNAS 4 in white is back in stock. Ordered one. Now I just have to order the Superlink for my door sensors.
So far my unifi setup is fine. A couple weird glitches - I replaced an edge switch with a unifi flex 2.5 switch, and now the unifi network app is completely confused about the network topology (everything still works - I think it’s just a reporting thing). And one of my synology NAS’s has 2 cat 6’s connected to a non-unifi switch. Both have fixed IP (192.168.1.21 and 192.168.1.22). For some reason, unifi decided that to report that they both have the same IP, and sometimes to report that they have different IPs but reversed from what they are fixed to be.). I went into the synology settings and set them to DHCP now, and then went into unifi’s network app and set them to have fixed leases with the proper IPs. It’s currently reporting the IPs are reversed. But everything works (I can even access via local DNS (set in unifi) via either port - each has its own local DNS entry).
I would say that these are just reporting errors, but at one point I did have trouble connecting to the NAS’s web interface for a few minutes while Unifi was reporting both ports had the same .22 IP address.
To be fair, some of these problems seemed to start when I enabled IPv6 on the local network. I turned it off, which seemed to help a bit. But since the NAS still reports it has IPv6 addresses as well, it may all resolve itself if I reboot the NAS (which I don’t feel like doing).
All of the IoT devices seem much more stable on unifi than they were on the synology network. Only glitch is an apple speaker that was having difficulty connecting to the internet until I moved it a foot away (there used to be a synology access point nearby, but I have one fewer access point with the new setup).
