what happens to the fermi level in a semiconductor as the temperature is decreased from 5 kelvin towards absolute zero
3:21 PM
Navigated freeze-out physics across doped semiconductor regimes
The short answer is that the Fermi level climbs upward (in an n-type sample) toward the dopant states, but exactly where it ends up at T = 0 depends on whether you mean an idealized intrinsic crystal, an uncompensated doped one, or a compensated one. The 5 K → 0 range is squarely the
carrier freeze-out regime, so doping dominates the behavior.
Why intrinsic is irrelevant here. For a truly intrinsic semiconductor, E_F sits at
E_F = (E_c + E_v)/2 + (3/4)k_BT·ln(m_h*/m_e*),
so as T → 0 it would settle to exactly midgap (the effective-mass term vanishes linearly in T). But at 5 K the intrinsic carrier density n_i ∝ exp(−E_g/2k_BT) is astronomically small (k_BT ≈ 0.43 meV against a ~1 eV gap), so no real crystal is intrinsic down here. Whatever dopants exist completely control the picture.
The freeze-out picture (n-type, non-degenerate). At room temperature the donors are fully ionized and E_F sits well below E_c. As you cool, thermal energy can no longer keep electrons in the conduction band, so they fall back onto donor sites — the conduction-band population drops exponentially and E_F rises toward the donor level E_D (located at E_c − E_ion). The limiting position at T → 0 splits into two cases:
- Uncompensated (no acceptors at all): solving charge neutrality n = N_D⁺ gives E_F = (E_c + E_D)/2 + (k_BT/2)·ln(N_D/gN_c), so as T → 0 the Fermi level lands halfway between the donor level and the conduction band edge. This is the exact analog of the intrinsic "midgap" result, with the donor level playing the role of the electron source.
- Compensated (a smaller acceptor density N_A < N_D is present): at T = 0 exactly N_A donors stay ionized, because those electrons have permanently dropped onto the acceptors and never return. Then E_F = E_D + k_BT·ln[(N_D − N_A)/gN_A], so E_F pins right at the donor level as T → 0.
Since real material almost always has some compensation, donor-level pinning is the more common experimental outcome. (Everything is mirror-symmetric for p-type: E_F approaches either halfway between the acceptor level and the valence-band edge, or pins at the acceptor level.)
The exception worth flagging. If the doping is degenerate — above the Mott criterion, where dopant wavefunctions overlap and form an impurity band that merges with the host band — there is no freeze-out at all. E_F is already inside the conduction band and
stays there down to T = 0; the material behaves metallically. So heavy doping breaks the freeze-out story entirely.
So the one-line summary: in a normally doped n-type semiconductor cooling from 5 K, E_F rises toward the conduction band, ending up either midway between the donor level and E_c (uncompensated) or pinned at the donor level (compensated) — unless the sample is degenerate, in which case E_F simply stays in the band.
