- Sep 26, 2021
Was that there from the beginning? I thought I remembered they published something a little later after the backlash started that was much more technical.
Pretty early on. This was from august of 2021. I think word of CSAM first started spreading a couple months earlier. Apple had an outline of this stuff pretty early. Notably, though, nobody stopped lying about it when this document came out. It changed nobody’s opinion. The theories were along the lines of “well, with this hook, apple could secretly change it so that the reference hash is different, or so that it reports to governments instead of apple.” Nobody ever had a good theory for why the system, as described by apple, was a problem in the form apple claimed it operated - they all assume apple is either lying or will secretly change it at the demand of governments and somehow nobody would notice.
Of course, if you believe apple will bow to government demands or that apple will do sneaky stuff, then they could do that without ever telling us about CSAM detection in the first place.
And nobody has explained how apple could change the reference database, or change it to scan text instead of photos (typical of the conspiracy theories) without anybody noticing. If they change the reference database, and the database is on the device, every security researcher will catch that in two seconds. And if they change it to use off-device reference databases, that is a completely different system than they have described, and nothing they planned to do would be of any use in implementing such a system, so what’s the problem?
The only righteous complaint is that there *will* be a very small number of people flagged incorrectly. And in *those* cases, apple *will* look at a low resolution version of the allegedly offending images to see if they are correctly flagged. Those innocent people will have had their privacy bent, if not broken, by Apple. But they won’t go to jail. The alternative, though, is *everyone* gets their privacy invaded. Because there is no universe in which some government won’t force apple to do something.
