- Aug 18, 2020
- iPhone
OK, so maybe this first post is specifically about kb+tp cases, i.e., keyboard + trackpad cases
, but figured I'd make it more general for future expansion
There's a few options:
Apple
Brydge
Logitech
A number of other named brands, several generics.
I think I'm mostly interested in the Apple vs. the Brydge, the latter original product had some janky gesture control, the new + models seem to have fixed this. I like the Brydge's larger TP, the function keys, it does use BT for connectivity, Apple uses the smart connector, supports a USB-C passthrough charger which is slick, the floating screen adjustment, it's thinner.
Kind of looking for an iPad-as-a-notebook solution, that will spend a lot of time on a desk, needs to properly protect the iPad too.
@JayMysteri0 I know you're a big iPad user, are you using either of these or something else?
Apple
Brydge
Logitech
