Initial thoughts: the most significant changes are obviously the move to MCM and the complete redesign of the CPU hierarchy. I did not see a more detailed explanation of the Fusion Architecture (maybe it is somewhere on the page, I did not look too hard), and I would guess that they have a CPU+IO die and a GPU die to get better die reuse.
Man do I have a lot of questions... many of which may never be answered. :-(
Are they running the entire memory bus through the CPU chip? Or through the GPU die? Since the GPU die is the only difference between the Pro and Max, perhaps the latter? I guess the alternative is to just not use half the bus width on the Pro's CPU die. Seems wasteful.
As to the new CPU core design and naming, this really took me by surprise. It looks like Apple is taking a very similar path to what Intel did a few years ago. Unsure how I feel about it to be honest. I'd like to know how the new cores are organized. Is that three 6-cluster cores (one "big" and two "small") or an entirely new hybrid arrangement of three "supercores" and six "cores"? Time will tell. I suppose the first option is more likely. I wonder what this means for the SME performance. Do we get only one big SME engine and two small ones?
So, the claim is that the supercores are just the M5 P cores. Makes sense. Maybe they're clocked up 100MHz or so.
The new not-E cores are definitely... not E cores. Accounting for lower P core count, total core count, sublinear multicore performance scaling, etc., and using reported M4 and M5 performance numbers as a baseline, I think the new E-ish cores are roughly 55% faster than the old ones. That's assuming Apple's reported MP 30% uplift is exactly right. If that's only a "best case" number, my number would shrink accordingly.
That means the new Eish cores are a bit over 150% of the performance of the base M5 E cores, and about 2/3 the performance of the M5 P cores. That's pretty good! Or at least, it is if they're still very power efficient. And I'm betting that they are close to the old E cores that way, or Apple wouldn't have dumped the Es entirely (and in fact, that must be right, given the battery life claims).
My initial reaction to this before I looked at the numbers was "meh". I mean, I was happy enough with the new machines but it seemed pretty much what I expected, though the core mix was odd. But now that I'm actually looking at these numbers... this is really pretty impressive!
It's also vaguely interesting that Apple chose a path closer to Intel's than AMD's in terms of making a smaller core. But that comparison may be misleading, as there may be no underlying similarities in tech.
