Attempted backdoor on ssh
Basically someone successfully inserted a backdoor into an upstream tarball for a library ssh relies on and thus compromising any server using Linux. It was discovered thanks to performance regressions and some valgrind errors on some systems.
Luckily xz 5.6.0 and 5.6.1 have not yet widely been integrated by linux
distributions, and where they have, mostly in pre-release versions.
Small projects create big risks.
Sustainability is a security concern.
jbailey
If you use homebrew or MacPorts you likely have the 5.6.1 version. For homebrew:
Code:
brew upgrade
It isn’t likely that your Mac is compromised but xz has been downgraded to 5.4.6 for both brew and MacPorts.
The back door specifically targeted x86-64, Debian, and systemd so it is unlikely that any macOS is targeted but downgrade anyway.
Andropov
Spain
Code:
brew upgrade
Interestingly I had 5.4.5 🤔
I definitely had 5.6.1 with Python3.8 and something else (I forget). You probably haven’t done a brew update in a while.
I also had 5.4.5.
It looks like 5.6.0 was released on Feb 24th, so it's been about 35 days that the exploit has been in the wild for people on bleeding edge. I'm a bit surprised how quickly Brew picked up the package, to be honest.
More on this aspect of the attack:
It makes for some chilling reading where the attacker took advantage of a maintainer being behind and struggling with mental health issues and then “helpfully” offered the solution of taking over using the usual online gang up to effectively force the original person out.
As the article states, this is so prevalent in open source software that this behavior alone wouldn’t even register as an attack.
IIRC, the undocumented thing was the bolts which got left out when the door was reassembled. As in, if they were following good process, all the parts taken off the aircraft should have been labeled and stored such that at the end of the job, they could inventory stored parts and easily see "hey there's some bolts here which weren't ever reinstalled!" Or even just look at the paper trail.
Or even a checklist for the repair (which apparently they did a lot), which required someone to take responsibility and initial that each step was completed.
Another similar case:
The recent attempted XZ Utils backdoor (CVE-2024-3094) may not be an isolated incident as evidenced by a similar credible takeover attempt intercepted by the OpenJS Foundation, home to JavaScript projects used by billions of websites worldwide. The Open Source Security (OpenSSF) and OpenJS Foundations are calling all open source maintainers to be alert for social engineering takeover attempts, to recognize the early threat patterns emerging, and to take steps to protect their open source projects.
