- Reaction score
- 8,805
This is a wiki post, where folks can list issues they’ve found in the betas.
IOS
IPadOS
OS Features
When trying to drag a window resize handle with stage manager enabled, sometimes you can’t. The issue seems to occur when two handles from two windows overlap (or nearly overlap)
Not a bug (probably), but tapping the background when in stage manager feels like it should reveal the springboard, but it does not.
Not a bug (probably), but apps that are designed to run full-screen cannot “window” with other apps; because of that, they should just automatically run full screen in stage manager, and not be shrunk to a smallish window (that can be manually maximized). This is especially the case if you are using stage manager without the dock and the recent apps list.
Maybe a bug: when a window is not maximized, certain gestures don’t work (like tapping the top of the window to jump to the top of a list)
It’s difficult to tell what the apps in the stage manager app list are sometimes, because they are small screenshots and aren’t labeled.
Scrollbars: sometimes the vertical scroll bar that shows up when you scroll UITableViews is in the wrong place when the window is not full-screen - the scroll bar shows up sometimes in the middle of the window. Killing the app and restarting solves it. So far I’ve only seen this twice, both times in Mail.app.
Books App
Opening a book shows no text - you can turn from page to page, but all the pages are blank. UPDATE: turns out the issue was that Books.app adds some new text customization options, and it defaulted, in my case, to white text on a white background. It may have something to do with a bug where it doesn’t like when your device is in night mode even though it is day time.
Mail App
Not a bug, but an annoyance: the same “left arrow” icon means “reply” at the top of the screen but “miscellaneous things you can do” at the bottom of the screen.
Music App
Apple Music features don’t work unless connected to wifi - connecting by 5G or LTE produces a “you’re offline” message.
Third Party Software
Using MobileIron MDM, apps that are managed by MobileIron and which need to launch MobileIron in order to start up don’t work because MobileIron crashes before it returns control to the app you are trying to launch.
Bugs when using physical keyboard:
Both of the following problems appear related to the app sometimes reserving space for the soft keyboard even though the soft keyboard is not present:
In Duolingo, while doing lessons, the text and controls jump around, as if the app gets confused about the window size.
In Citrix, a keyboard bar runs horizontally across the middle (vertical) of the screen, just above where the soft keyboard would be if there were one.
