- Sep 26, 2021
Given that their E-cores are fairly compact, and also quite capable, it seems like it might not be that difficult. Construct FutuArch, which will have a streamlined decode scheme and slightly different behavior patterns, and put it into FP-cores and FE-cores while still retaining 4 or 6 xE-cores to support legacy code. Five years down the road, the chip will be down to 2 xE-cores and may never be able to get past having one in there, but all the important software will have been rebuilt for or translated to FutuArch, which will be a tremendous efficiency gain over x86-64.
The last time Intel came up with a new easy-to-decode ISA it didn’t turn out so well for them
