exoticspice1
- Jul 19, 2022
Very little GPU improvement in A16. No wonder Apple did say anything new about the GPU.
talkedabout.com
That only applies to Mx Max and Ultra chipsets.A16 Bionic
A dedicated thread to talk about Apple's latest chip :) Seems like this leaked Geekbench result (https://browser.geekbench.com/v5/cpu/17141095) is more in line with expectations: 1887 in single core, 5455 in multicore (+9.2%, +13.4%). Interestingly, the biggest improvement in multicore is in...talkedabout.com
This has just been discussed. GB has issues with ramping up too slowly on ASi. Antutu shows a much healthier improvement. I have no idea how reliable or reputable Antutu is however!
Hence I'd expect that the same frame on a A16 Bionic with +50% memory bandwidth to be around (gross estimate) ~9% faster due to memory bandwidth improvements alone.
That's a 14509 -> 15807 = +8.9% in GPU performance... almost exactly what I estimated from bandwidth improvements alone. Hmm.Very little GPU improvement in A16. No wonder Apple did say anything new about the GPU.
Hmmmm. We don’t really know that it does scale well on the A series. It’s true that previous generations showed a bigger leap, but the issue was ramping up regardless of chip size. It’s quite possible that it underestimates performance on all Apple Silicon chips, and that some modifications would yield hiher scores all round. Hence the better performance on other benchmarks like gfxbench and Antutu.That only applies to Mx Max and Ultra chipsets.
Geekbench is fine to use for the A series and Mx base series. Previous A series chips in the GPU test have shown huge improvements. For example the A14 iPhone 12 Pro scored around 9300 and A15 on iPhone 13 Pro scored around 14500. So ultra mobile chipsets Geekbench is fine to use.
Thats because the GPU is the same. I don't see M3 being based off A16 GPU and M2 already has LPDDR5.That's a 14509 -> 15807 = +8.9% in GPU performance... almost exactly what I estimated from bandwidth improvements alone. Hmm.
I completely agree with @theorist9. I pay attention to what the PC crowd are doing, because I am interested in technology. However, there's absolutely nothing that Microsoft, Intel, AMD, or Nvidia can release that's going to persuade me to switch from the Mac. In fact, with the way PCs are getting hotter, noisier, and guzzling more energy, they're heading in the opposite direction. It doesn't help that the operating system and ISA are covered with barnacles accumulated through decades of mismanagement, with the inability to cut out cruft and dead weight.[I don't fall into either category; for me, the OS and my attendant user efficiency and experience are paramount, so I use a Mac.]
it’s a single benchmark in the sense that it collects the results of multiple workloads and produces a single score which is what most people look at.Geekbench isn't actually a single benchmark. It's a self-contained suite of many benchmarks. It generally appears to have been inspired by SPEC, and has been shown to correlate very well with SPEC.
Sure, was just saying that it's got a variety of loads under the hood.it’s a single benchmark in the sense that it collects the results of multiple workloads and produces a single score which is what most people look at.
even chip designers, who think in terms of SPEC, do not rely just on SPEC. You want a whole array of benchmarks from different sources with different philosophies, different workloads, different runtimes, etc.
Are single-precision (FP 32) TFLOPS a good meansure of general GPU compute performance?
Perhaps. But if a benchmark shows no improvement it’s a questionable benchmark - the increased bandwidth should cause an increase in performance.Gfxbench shows no improvement. So A16 and A15 have the same GPU.
Where have you found a Gfxbench benchmark of the A16?Gfxbench shows no improvement. So A16 and A15 have the same GPU.
But that same benchmark had showed increased pref before you know when Apple actually improved the GPU.Perhaps. But if a benchmark shows no improvement it’s a questionable benchmark - the increased bandwidth should cause an increase in performance.
