bunnspecial
- May 20, 2021
So, little update on the MG...
I'm not sure if I mentioned it here, but I'd had a small oil weep from the differential for a while that I decided, while I was doing the rear suspension work, to tackle. I ordered two gaskets(two just to be safe), spent entirely too much time cleaning up the faces of the differential and cover, stuck a gasket to the cover with Permatex and let it set up overnight, and bolted in place.
I filled the differential full of 85W-90 GL-4 spec gear oil. That is worth a mention as essentially all gear oil available at auto parts stores now is GL-5 rated. The GL-5 spec calls for a much higher concentration of sulfur-based EP(extreme pressure) additives, but like all API oil ratings it supersedes the prior spec.
That's all good and well except that the sulfur EP additives are very corrosive toward yellow metals. GL-5 spec oil is absolutely off limits(or should be) in manual transmissions with brass synchros. It's also not a good idea to use in MGB differentials(and I'm sure some other older ones) because the thrust washers are bronze and a few other important parts are brass.
Amazon came to the rescue and turned up 85W-90 GL-4 oil.
I filled the differential up to the fill plug, put the plug back in it, and called it a day.
After the first trip out, I noticed oil on the ground. I didn't think too much of it since I'd initially been a bit messy filling and thought maybe I was seeing some drip off still.
It kept leaking, though. I snugged up all the bolts and put a wash tub under the differential that had several ounces in it the next day.
So, this week, another quart of GL-4 made its way here. I just finished tackling the cover again. I pulled it off, cleaned it up, and this time went a different route. I've been told that a lot of current gaskets are junk, so instead I just slathered the cover with Permatex Form-a-Gasket, and specifically the kind meant for rear differentials. The instructions said to put it in place, loosely attach the cover for an hour, then torque to spec(good luck getting a torque wrench back there-I went mechanic tight on them) and let it set up for 24 hours before adding oil. Hopefully this will fix it. I'll know tomorrow.
Also, the rear brakes have been my nemesis. These are manually adjusted, and especially after they're first put together it can take some driving for them to "seat" and actually adjust right. You can tell they're out of adjustment from two things-really long travel on the E-brake handle, and a mushy brake pedal(feels like air in the line) that improves when you pump or when the hand brake is on.
I readjusted the brakes today, and also fixed another embarrassing bodge. Somehow or another in all the disassembly, I'd lost the clevis pin for the hand brake cable on one side. This was bad, but I found a screw about the right size and zip tied it in place just to have something. I visited the hardware store today and fortunately they had clevis pins, although they're "universal" ones with a half dozen holes drilled in them and a couple inches long. I really should cut it off to the right length, but it works for now.
