Apple fanboy
- Oct 14, 2020
Installed today. Still hoping I can use the work ones as I often as I have been though!
Have to be honest the sort of current these home chargers deal with, I wouldn't want to be messing. I think I've used my home charger all of about 3 times since I had it installed. I'm sure you could find an off the shelf option that would do this for you?Hope you don't mind me putting a related post in this thread rather than starting a new one.
I've also been looking at EVSEs, and have been looking at ClipperCreek since it needs to be installed outdoors, and I'd much prefer something reliable and built like a tank. I noticed they have an add-on you can get that's called "ChargeGuard" which takes either a key or uses external low-voltage wiring to lock/unlock charging, similar to what the EA unit can do via the app. Bridge the wires, you can charge, disconnect them and charging is locked out, bridge them momentarily to only charge the currently connected vehicle. So this got me thinking:
- DC/DC SSR hooked up to a Raspberry Pi and these control wires. Mount this in a project box inside the garage. Maybe add an override switch that can unlock the charger in case the Pi or the SSR is misbehaving.
- Mount the unit outside the garage, as normal.
- Write up a small web app + REST API that can lock/unlock the charger. Add a little state to the thing, and it can do scheduled charging or allow charging during certain times of day.
Hmm... I smell a possible DIY project here.
Sounds like it could be fun, though it seems like most BEVs have pretty sophisticated scheduling right in the vehicle (and most smart "chargers" have some kind of scheduling/analysis portal). Sounds like maybe you're looking for improved security as well[?]
My first thought was garage door opener switch.But here's the thing, this isn't me messing with the unit. The unit would arrive with a pair of control wires that are intended for the buyer to integrate into some sort of access control system. Normally that means hooking it up to a system that reads RFID badges or the like and checks them against a list of authorized users, but it can just as easily be anything that can close the circuit on these control wires so long as it's designed for the voltage. These are low voltage wires that run very little current through them. It could be hooked up to a simple switch off DigiKey or Mouser, really.
Yeah, that sounds like their commercial type models. Since ours is installed inside a garage (and we work from home - and someone is always around), someone creeping up and stealing free electrons isn't much of a concern, but I can see plenty of situations where that could be an issue.
It could also be I am a little paranoid. We haven't decided on going this route, but this wouldn't be the first Pi-based controller I've assembled.
Huh, that is an idea. I went on a bit of a tangent, but reading this made me look along those lines and I ran across a multitude of Chinese-made relays that can be controlled by a key fob like remote. Something like this could be hooked up straight to the control lines.
Yeah, that would work. I haven't worked with garage door circuits, so I'm not super familiar with how the units are meant to be driven, but it seems like it would be fine for one-shot use like you say going from the details on the MeRoss.I was thinking something like the MeRoss homekit garage door opener. Maybe the one that can control two doors. If you want a one-shot, you use it as is, and you hook up the other output to a flip-flop for a persistent signal. All controllable by homekit. Seems like fun.
Raspberry PI would be stronger geek cred, of course. I’ve got two around the house myself. One running homebridge (needlessly, as I could run it from a server I already have on all the time). Another was a hack job on an Arcade1up machine where i gutted the internals and replaced with a Pi. I had a couple more projects in mind but it’s too hard actually finding raspberry pi’s lately![]()
I have a couple that are between projects right now, especially after tearing down the second aquarium and moving the Pi-hole to a VM, and I also have one I keep around specifically for development purposes.
But I honestly think I could get this working and tested before the EVSE arrives and gets hooked up. The core of it could probably be built in a weekend, and maybe a second weekend to write a homebridge plugin for it and draft up a project box in CAD for it.
