not sure when this started but my system has been getting really slow then this warning would pop up. so safari is really causing serious memory uses.
nothing has changed in a year but os updates. same tabs for the most part. but it happens over and over again as I use it. for the most part my system is always slower now.Looks like a memory leak, that's where memory gets used (allocated) and then not reallocated/cleaned up, so it just continuously consumes more and more RAM. I guess I'd start by disabling all plugs-ins/extensions and of course, make sure your OS is up to date.
It could be a specific website. Probably some crappy JS that's leaking all over the place.nothing has changed in a year but os updates. same tabs for the most part. but it happens over and over again as I use it. for the most part my system is always slower now.
that could be most of the time all my tabs are what I always have open. I know I get notices from Facebook about using a lot of resources and also google maps. but they have been up forever.The leak could be the fault of a poorly written page script. Sites like Raw Story, for example, have brutal coding (and they are far from the worst offender).
Yep, I would recommend this. Narrow it down site by site. It's likely some website you visit changed something either visibly or not visible like some under the hood code that is doing something wonky.I'd open on at a time, observe the memory consumption, close, open, etc., Since we're talking web related code, the site can easily change what they're doing and greatly affect your end. There was a site I was occasionally hitting, not particularly media intensive or anything, but it would spike my processor utilization, and actually cause the fans on my Mini to kick into high speed.
