- Reaction score
- 8,536
iPhone 14 design to feature even larger camera bump - 9to5Mac
Apple is doubling down on the camera bump with the iPhone 14 design. The camera bump will reportedly get even bigger thanks to a new sensor..
9to5mac.com
According to Kuo, the 14 will have a bigger camera bump due to a 48MP sensor on the wide camera. Increasing the megapixels ordinarily would be a wash, but I assume this means they are also increasing the size of the sensor. And since the image from the wide lens is used computationally when forming images from the other sensor(s?), having more megapixels to work with should increase the performance of the other lenses too, I’d imagine.
That said, a pill-shaped hole to replace the notch and another camera upgrade might not make for much of an upgrade over the 13’s unless there’s more.
Sounds like iPhone 15 will be the big jump, with periscope lenses to eliminate the camera bump, and under screen faceID to eliminate the notch.
