- Reaction score
- 3,011
- Fujifilm
I am preparing to submit some images for consideration for publication. I've had some images published before, but they were digital, and this is a new film only magazine. The requirements for submission are as follows:
Most that I am considering submitting I've scanned at home, so they have the resolution of my Z6 and hitting those requirements aren't a problem. I have a couple of lab scans that are considerably smaller in terms of MB but do hit the pixel dimensions. I've already sent in a question to the organization if a smaller MB size is okay. I realize they want high quality images to have the best quality for printing. My smallest MB size is 2.2mb, which still doesn't seem very small, and I know there is a correlation to the amount of "busyness" in an image and file size. The small file is a relatively simple frame.
I am guessing that I should just camera scan the smaller files, but I like the colors/contrast I have and am worried I won't be able to replicate that with my home scanning process. I'm just baffled by the 5mb minimum as I am used to submitting things with a maximum resolution. Especially for film where the resolution is limited by scans.
I'm not sure I have a question, really just sort of wondering out loud here.
Images MUST be a minimum of a 5MB file size (2700 x 1800ppi minimum file size), else they cannot be considered. You can find out the image dimensions of any scan on any computer, using ‘get info’ for example on a Mac
