- Sep 26, 2021
TSMC to Begin 3nm Chip Production Next Month
3nm chips from TSMC are getting closer.
I wonder if Apple will be able to use this for the M2 Pro/Max/Ultra?
If i remember correctly that will be the 2nm node, where they go to the wrap-around gates.Is this the process that is described using pairs of numbers, like 3-2 is a different power-draw-switching profile than, say, 2-1 so the actual "metal" configuration will at least partially determine P vs E designs?
It looks like "FinFlex" is a 3N methodology whereas 2N will be using a "nanosheet" arrangement.
4GHz
Yes, apple’s design will work fine with all cores at the top speed; that’s one of the advantages of being power efficient. You don’t have to worry about IR drop on the power rails, or on thermal hot spotting that bleeds over into neighboring cores.Not sure about what N3 can offer, but Apple has been extremely conservative with clock speeds on their SoCs. I remember looking at the Mac Pro XeonW, where the model options where clock went down as core count went up, and most Anthill CPUs slow down as more cores are recruited. I suspect Apple wants to pick a baseline speed and hold to it howsovever many cores are pumping, up to nearing TDP limits. "Turbo-boost" is such BS, that Apple wants to avoid.
Further to the above, i am predicting a clock speed increase. Around 4GHz on the performance cores.
Yep. Maybe even a 2xUltra for Mac Pro.M2 powered Studio machine should be pretty tastyI guess we'll see an M2 Max and M2 Ultra?
The people over at the other place keep insisting that it's going to be another Xeon Mac Pro, Apple wants to "keep pros happy", and because they paid more for their machines than the lesser Mac plebeians, they deserve at least 10 years of support, and continued parallel x86/Arm development.Yep. Maybe even a 2xUltra for Mac Pro.
I did some babysitting over at the Mac Pro forum recently. While demanding all of this from Apple, they also compare the company's management to infectious diseases, say that the NIH has to clean them out, and anyone who says otherwise is sharply denounced. In the same breath, they claimed that "this forum (MR) was instrumental in getting Apple to change its plans for pros", and they cite statistics that people from Cupertino visit the site as proof.
I don't understand how comparing Apple to the bubonic plague is going to convince anyone to release another Xeon Mac Pro, but that appears to be the common attitude. There's also this supreme sense of entitlement, comparing the MacBook Air to a "diaper for children", and the belief that because they spent more on the Mac Pro, they therefore deserve special treatment. I then quoted the various things you expect from the next Mac Pro, provided direct links to this site, and mentioned your credentials. They were not happy. I also invited them to come over here and ask you about your thoughts on the Mac Pro and Apple Silicon. Curious, but for some reason, nobody I chatted with has bothered to ask you, thus far.
This all started when the guy who originally leaked the Mac Studio also leaked that the upcoming Mac Pro used the same Apple Silicon that every other Mac uses, just scaled up, and the test board only had one PCIe slot. I'm not sure what stage of grief they are at, but right now it seems to be anger. I guess bargaining comes next. Acceptance either comes when they purchase the Apple Silicon Mac Pro, or punish Apple by switching to Linux or Windows workstations. At least they'll get their Xeons. I honestly can't wait until the next Mac Pro is announced. I'm going to lurk over there just to watch the implosion.
