- Sep 26, 2021
From: https://www.anandtech.com/show/1702...cialflow&utm_source=twitter&utm_medium=social
Some highlights
Conclusion:
"On the CPU side, doubling up on the performance cores is an evident way to increase performance – the competition also does so with some of their designs. How Apple does it differently, is that it not only scaled the CPU cores, but everything surrounding them. It’s not just 4 additional performance cores, it’s a whole new performance cluster with its own L2. On the memory side, Apple has scaled its memory subsystem to never before seen dimensions, and this allows the M1 Pro & Max to achieve performance figures that simply weren’t even considered possible in a laptop chip. The chips here aren’t only able to outclass any competitor laptop design, but also competes against the best desktop systems out there, you’d have to bring out server-class hardware to get ahead of the M1 Max – it’s just generally absurd."
Some highlights
- GPU running at 1296 MHz (max). That means it has a very high "IPC", since many cards with comparable performance run at much higher frequency
- 512-bit wide LPDDR5
- 48MB SLC cache
- Cores: 3.2GHz peak, 128KB L1D (3 cycle load-load latency), 12MB L2 cache
- 15ns slower DRAM latency as compared to M1
- Single core can saturate up to 102GB/s memory -- 2 cores 186 GB/s -- 3 cores 224 GB/s -- 4 cores 243GB/s, which is maximum the CPU cores can stress. So the CPU cannot, itself, use all 400+GB/s.
- Power usage all over the map. 0.2 W at idle, 34 W CineBench r23 MT, 92 W Aztec High Off + 511.povray_rMT.
- In all cases, less than Intel i9-11980HK, often much less, while achieving comparable-to-much-higher performance.
- As expected, single thread performance comparable to M1
- Multicore: Generally trounces AMD Ryzen 5980HS (35W) and Intel Core i9-11980HK (45 W)
- On specfp memory-bound tests (which, I know from experience, is something cpu designers think about), it's performance is "absolutely absurd."
Conclusion:
