Now they are deleting your posts on thermodynamics. Pathetic.The mods went through and deleted a bunch of stuff, looks like.
That is a major problem with how they moderate. I would consider using the contact form to request that they replace your post. They allow one or two bad posters to ruin other people’s posts because the mods wipe everything instead of just the offending content.What seems to happen is that someone personally attacks me, and then tells me i am wrong because of incompressible fluids or the reynolds number or whatever. I reply, and edit out their personal attack and just respond to their technical stuff. The mods delete their attack post, but then delete all the following discussion that responded to it, even though none of the attack was copied into those posts.
They probably won’t give a shit though. They will just wipe a whole thread because they feel like it and tell you to go F yourself if you complain.
Do you need more drama in your life? Because, I tend to be fine without it.Oh. Looks like I missed the drama.
Just a bit. Not much. Enough to not get bored.Do you need more drama in your life? Because, I tend to be fine without it.
That was a fun guyThere’s a thread over at the other place where some guy is complaining that Tj is 100C. I tried explaining what that means and why he shouldn‘t worry, but he has built his own PCs, so his expertise is superior.
It's probably best if you don't directly quote those folks at all and just phrase a general comment like: "Those who question my point of xyz, let me add..." That way the usual quick and dirty mod jobs don't affect your posts that much. At least I hope....What seems to happen is that someone personally attacks me, and then tells me i am wrong because of incompressible fluids or the reynolds number or whatever. I reply, and edit out their personal attack and just respond to their technical stuff. The mods delete their attack post, but then delete all the following discussion that responded to it, even though none of the attack was copied into those posts.
I tried changing my reference from using the word Troll to references like "individuals who appear to reside under bridges"....seemed to work ok.
Hahaha. Nah, they'll just use it later on as an excuse for a permaban. I tested this too, by referring to the pupils of the Nordic Hillside Academy. Was used as justification to ban me from PRSI. That's OK though. If they penalize people who add actual content over trolls, then the culture they foster will be their long-term headache.I tried changing my reference from using the word Troll to references like "individuals who appear to reside under bridges"....seemed to work ok.
Trawling is with a net. Trolling is with baited lines. That image looks like trolling rather than trawling.That's trawling.
