- Aug 18, 2020
- iPhone
Just setup a service appointment for two issues, first is that on hills in San Francisco (when the car self-breaks) it squeaks really loud and has been this way since the beginning. The other is that when I go to start the car after it's been sitting for a while the USB drive shows disconnected and I have to reseat it, I've tried with multiple drives so it's on the car side.
Other than that it's been great to me so far, I also added liners I got on the cheap from Amazon to the roof because the sun really heats it up, hoping to shave a few degrees off in there and save some battery life.
Are they doing at home service? Though if you're close to an SC, it's probably easier for a service that might require the wheels to be removed (for a brake inspection, etc.)
Funny you just ordered some sun shades ...
I've never used anything in the front window for any car I've owned, but since the windows is so huge and we're taking a trip where it will likely be sitting outside for a week, figured for $25, it couldn't hurt.
Also ordered this:
Figured if I can find a nice shady spot under a tree, it'll keep stuff out of the AC intake better
