I agree that, most likely, if third-party GPUs are offered in the Mac Pro, then they will be entirely add-ons, not default. However, I see that as a bad thing, period. I'm looking at this from the perspective of a desktop user, I'm a stationary sod, and don't care about battery life and portability. As long as my computer doesn't sound like a jet engine, then I'm good.
I'm not in the market for an Apple Silicon Mac Pro, but as the flagship desktop product, it will reflect upon the rest of the line. Assuming the rumors are correct, which is a big
if, then I'm not seeing any encouraging signs.
Even though we've talked ad infinitum about the M2 "Extreme", there was an equivalent in the M1 generation, Gurman's Jade 4C-Die. The original Mac Pro prototype mentioned by the leaker on MR, who has access to early hardware,
said as much. So, the M2 was actually Apple's second attempt at an "Extreme" SoC for the Mac Pro, which also means this is their second failure. We don't know why they decided not to launch, just that this isn't their first ride on the Extreme rodeo. (For what it is worth, just today, that same poster
is reiterating what he said previously about the next Mac Pro.)
With the apparent failure of the M2 "Extreme", the amount of GPU power available is going to be no better than whatever ends up in the high-end Mac Studio, featuring an M2 Ultra. The simple fact that Apple may have to depend upon third-party GPU cards at all is not encouraging, and another failure, from my perspective. The M1 Ultra matches an RTX 3060, at best, which makes the comparison that Apple made to the 3090 embarrassing.
Then there is the M2 itself, which Gurman called a stopgap. It would be fine if this were a short-term release, but it's being stretched out longer than most of us had expected. We also have the leaked Geekbench scores for the higher-end M2 variants, which are lackluster, at best.
I've heard much talk about global events being to blame for this, but I simply don't buy that, at least not as an excuse which Apple can hide behind. Nvidia's Lovelace, Intel's Raptor Lake, and AMD's Zen 4 and RDNA3 have all been, more or less, on time. The exception is Arc, and I give Intel a pass on that, for obvious reasons. Apple is the most valuable company on the planet, with a "supply chain master" at its helm, yet it couldn't adapt like their competitors? Maybe the pandemic is the cause, but Apple is to blame, because they should have adjusted, but didn't.
Perhaps the M3 generation will fix all ills and ailments, restoring balance to the silicon sphere, but I don't make product purchasing plans based upon maybes. As a desktop-only user, I care about performance cores and GPU. The P-cores appear to be virtually unchanged in M2, based upon Geekbench leaks, and now Apple may need to trot out third-party GPU cards for the Mac Pro, which is embarrassing, no matter how optional they may be.
At the end of the day, again as a desktop user, my concern is that Apple is simply taking recycled laptop chips and slapping them inside compact desktops without any enhancements. That was fine for the M1 generation, but I want them to scale beyond that. If the GPU for an M2 Ultra, which appears to be the only option inside the Apple Silicon Mac Pro, ends up being equivalent to a theoretical RTX 4060, then that's another loss that Apple will take.
I joke by stealing
@theorist9's line that "I'd use macOS if it ran on vacuum tubes", but if Apple continues to ship warmed over laptop chips inside their desktops, and the only way to get something better than Nvidia's entry-level graphics is to get a Mac Pro with optional third-party GPUs, then I would be forced to consider PC by default, simply because Apple has given up on the mid-range desktop market. We'd be forced to chose between compact desktops with laptop performance, or an astronomically priced Mac Pro + third-party GPU combo.
It would be like the bad old days of the G4/G5 stratification at the end of the PPC era, except the professional desktop would be even more obscenely priced, with no middle ground.
Yes, that's a lot of "maybes" and "what ifs", but I'm not at all encouraged by what I've seen, thus far. Nor am I heartened by what few rumored breadcrumbs we've seen from the future. The M3 may be the greatest thing ever, but it also may be another warmed over M2, depending on how correct those brain drain reports were about Apple losing engineering talent, technical accuracies of said reports aside.
As a Mac user since 2005, I don't want to have to even consider getting a Windows PC, but if Apple can't match even a 4070 with Apple Silicon, then I really don't see a future for them in mainstream desktops. I hope my pessimism is wrong and entirely a result of Apple's secrecy. The fruit company had a honeymoon period with Apple Silicon on the Mac, and I am concerned that the bloom is wearing off, not just in perception, but reality.
