Sonos Sub Mini announced and available for pre-order! Woot!
Yep, the Sub Mini, delivered is $754 with a Ray, or $935 with a Beam (Gen 2) That's a pretty killer, wireless, very little spaced used, surround setup for those prices!
Power Reset to get your TV to turn back on
I have. 55” Sony TV that has been relegated to our bedroom. It’s about 10 years old. Periodically it will not turn on. I’ve double checked power available to the TV and found this article:
Will Your Sony TV Not Turn On? A Few Common Fixes
The Sony brand is synonymous with top of the line electronics, and their TVs certainly meet those expectations. But what do you do when your TV refuses towww.alphr.com
It mentions a power reset. Unplugging the TV for several minutes, then back in fixed it. I’m wondering what would cause the need for a power reset? I was gone last week and there was a power surge/loss of power momentarily and I suspect that is the cause.
Any TV technicians reading this?
Gen 2 Beam has Atmos now . Would it be an improvement over the my Playbase, I wonder? It’s a small space so I don’t need a ton of power. I’ve avoided the Arc due to price and seems like overkill for that space.The Mini Sub + Gen 2 Beam is actually $833 when purchased together (at least for now, it is a "sale"), that's a pretty sweet setup for under $900:
Entertainment Set with Beam & Sub Mini | Sonos
Turn your small or medium-sized room into your personal home theater with a compact smart soundbar and subwoofer from Sonos. Sub Mini balances out the lowest frequencies so Beam sounds even better. Stream music and more over WiFi using the Sonos app, your voice, and Apple AirPlay 2.www.sonos.com
Thanks for that info. I have a couple of Play Ones also. Looks like you can add them up for a max of 30% off a purchase. So, looks like I could get a Beam Gen 2 for under $315.It's supposed to be pretty solid Atmos, even though it doesn't have upward firing speakers, and just generally outstanding sound, clarity (excellent for dialog in movies), and I can't tell you how handy the voice control is for volume.
Did you know you can get a 15% discount from your Playbase? They have an upgrade program, check into it, I think that qualifies.
20% off on a few items, NOT the new Mini sub, and only one item, butI went ahead and got a Beam Gen 2 for the bedroom 20% on Sonos pretty decent and I can score a sub later.
Ok, so dumb question.
Do these soundbars come on with the TV? Or do you have to turn them on separately?
My answer is similar to DTs. I have a Sonos Playbase, which is an older piece of gear than his Arc, and it just comes on when the TV wants it to. There’s no remote or power-on to think about. Sonos is awesome, and works very well with Apple products, too.Ok, so dumb question.
There's no dumb questions ...
As you'll see below, there's only dumb answers
For the most configurations, I'd say they come on with the TV or are just on. Like the Arc/Sub setup on the TV in the family room is always on, I send music to it from Spotify all the time, without the TV or AppleTV on, I never think about the power status. For the bedroom and family room, both TVs use an AppleTV as the only source, so we press one button on the ATV remote, and the TV comes on too (via ARC/eARC, not to be confused with the Sonos Arc soundbar) and the soundbar is just kind of always on standby.
That's a really nice thing about soundbars, at least the Sonos products, it's super seamless, it's basically like the TV audio, regardless of how the TV gets audio, from an external device like AppleTV (or Fire, or whatever) or from internal "smart" TV apps.
