I haven't seen any other reviewers with the 14" M5 Max model - I don't know why they shipped that to NotebookCheck. Also some of the gaming data is corroborated with other reviews. So the Max GPU appears to be inconsistent even with the 16" model. Though it isn't all bad, the 14" M5 Max is ridiculously efficient in CP2077 in their data, even compared to the other M5s tested (well the very low power M5s in the Airs are still better, but the 14" Max is pushing that level of efficiency). Most of the odd 14" results could be explainable by a chip that is throttling or at least being deliberately constrained more than it should be, maybe a "hot" chip or a fan curve that isn't working right - setting it to High power mode as they did *should* have alleviated that, but there are other power curves than just the fan. We know that the 14" has historically struggled to cool the full Max chip in the past and we know occasionally Apple has shipped devices with ... imperfect cooling/power curves that had to be corrected after launch (typically iPhones more than Macs). So that's another possibility, beyond a bad/hot chip - which as you say is unlikely but possible.Nearly all of the reviews of the M5 have been so badly produced I can't take this conclusion seriously, especially not when it's contradicting other reviews I've seen.
We need more testing from more people, because the thing I've pointed out that no one is talking about: it can outperform M3 with 80 cores and 819 GBs of bandwidth at full load. Something isn't adding up here for their review. They could have simply gotten bad chip, which is unlikely but possible.
That said their CBR24 data for 16" M5 Pro review bothers me more, that MT result doesn't just look wrong, it should not be possible - have you seen any other reviewers with that model? The other results for that model seem sensible enough (including ST), but ... that one ...
Unfortunately very few outlets measure wall power efficiency, at most they might look at powermetrics (which is not bad data, but not complete and not useful for my purposes). Notebookcheck isn't the only one that does so, but there aren't many and even fewer that do so regularly and none so easy to get lots of data for.
