M5 Pro and Max unveiled
Yeah I guess I’m put off by the headline that the Max showed little improvement when what they mean is the 14” shows little improvement when compared to the 16” M4 Max
Fair, the one note of concern though is that the 16" Pro has the same CPU but with cut down memory bandwidth as the M5 Max and for some reason it's slower than the 14" M5 Max and is less efficient as well! Every previous time I've gone with the "it's the memory bandwidth" hypothesis to explain odd CB 24 results, I've usually, eventually, come to the conclusion that it wasn't. But here ... again, I don't know how else to explain this even though, as CPU bandwidth goes, the M5 Pro has a ton! (Not sure how much it can access admittedly) I mean, workstation CPU level bandwidth. So I dunno what's going on.
So it can't just be the 14"'s lack of cooling.
From @JRLMustang: https://arstechnica.com/gadgets/202...ook-pro-m5-max-and-its-new-performance-cores/
The M5 6-E-core cluster has 6MB of cache while there are a 2 clusters of 6 "P-"cores each with 8MB of cache and the 6-"S-"core cluster has 16MB.
This Ars article has the M5 Max CB 2024 result at 2300. Why the M5 Pro with the same CPU only gets ~2050 while drawing >100W (basically matching the M4 Max with much higher power draw) is ... unclear to put it mildly.
More Cyberpunk benchmarks. The lack of increase in some scores is weird. Again from Hardware Canucks
This Warhammer 3: Total War shows a similar lack of improvement.
I dunno ... driver issues?
Yeah could be. Or just a lack of optimisation overall?
So no 1 MB private L2 like some rumour mongers were saying?
It's interesting how M5 Pro/Max are getting by with relatively less cache compared to the competition.
SoCL2L3Total CPU cache
Apple M5 Max16 MB + 8 MB + 8 MB-32 MB
AMD Strix Halo1 MB x1664 MB80 MB
Qualcom X2 Elite Extreme16 MB + 16 MB + 12 MB44 MB
Intel Core Ultra 388H(3 MB x4) + (4 MB x3)18 MB42 MB
From X unfortunately but here is a test Max Weinbach did comparing a mobile 5080 on power vs M5 Max on battery. All settings maximum accept path tracing. 5080M 27 fps, M5 Max 23 fps.
With path tracing it’s 17 fps for the 5080 vs 13 fps for the M5 Max
There is a video on X of this test.
It's possible its a misunderstanding based on what @leman was saying that each core has a slice of L2 that isn't exactly private but is also considered "for that core", just that other cores can also see it ... unless I also misunderstood what he was saying.
Don't forget that Apple and Qualcomm also have SLCs which function like an L3 - although their L2 also sort of functions like an L3 since it is per cluster rather than per core. Very different cache philosophy - partly because Apple's L1 is so big. Intel also has "L1.5" - which I think really is L1, or maybe I screwed that up, but I remember them adding another layer. .
